Nice. Now the fun starts getting them charged.I have now completed my first Lishen 272Ah test as well. 285,64Ah removed. Two cells at 2,891v and one cell at 2,754v and one at 2,810v
Yes, they are charging now at 50 amps.. Hopefully they will stay balanced..
I wish I had bought that power supply. I'm on day three of my top balance and I'm still under 3.4 volts.I did allready topbalance them, but did that at 50 amps 3,65v as well!
I've bought this great converted server power supply on ali... : https://www.aliexpress.com/item/4000280014850.html
Will recommends a good set of tools on his site. https://www.mobile-solarpower.com/tools.htmlJust ordered 16 x 272s off an alibaba, first time lifeper here, gotta research all the tools and balancing, any recommendations?
onlinemetals.com is the best place I have found for copper bar. https://www.onlinemetals.com/en/buy/copper-rectangle-barWill be making my own bus bars as these will not come with them for a discounted price.
If they come balanced, can i just slap the BMS on it and start using?
For simplicity and to reduce connections I would make up four hole and eight hole bussbars and layout the cells differently in columns. I wish I could draw a picture but it may depend on how much room you have for columns and rows. If you go to this resource and look at any of the figure E diagrams and scale up you may get a picture of what I am saying. https://diysolarforum.com/resources/cell-configurations-for-12v-24v-and-48v-lifepo4-batteries.123/[*]Any issues with how I've planned to configure the bus bars and the stock I plan to use?
I would use one 4/0 cable from the center or end of a buss bar connected to a separate hole and fuse just that connection. I prefer not to use the small 6mm connections but rather 5/16" or 3/8" lugs. Are you actually loading that pack up to 600 Amps? If less you might be able to get by with 1/0 in open air.[*]Do I need to fuse the 4x leads (individually) going to the 600A bus bar? If so, what size fuse?
I would pick a BMS that can communicate with my inverter. I think others have found some that connect with Schneider equipment. It may have a separate on off switch that could be triggered by the BMS. I would also consider a KiloVac contactor. It may depend on your anticipated current whether there is a SSR that can handle 600 Amps.[/list].......
[*]I'm trying to decide on a BMS - thoughts on this as it relates to this battery and my other equipment:
If you use silver flashed copper, make sure the silver is polished before assembly, The silver tarnish is a lot less conductive than copper or copper Oxide. Presumably, the silver will not tarnish where it is pressed against the terminals (and/or itself), but I can't be sure of that.I'm thinking of making my own bus bars from onlinemetals.com - .25" x 1" silver-flashed copper bar:
I assume the 4x leads are to try to keep things balanced between cells. I would make the 4-hole 'end' busbars extra heavy duty for the same reason I outlined for the 8-hole busbars above. This attacks the problem 'at the source'. However, as my model above shows, it can not totally eliminate it. If you make the busbar extra heavy duty and do like @Ampster suggested with a tap in the middle you should be 'good enough'
- Do I need to fuse the 4x leads (individually) going to the 600A bus bar? If so, what size fuse?
Doing similar modeling as for the 8 hole bus-bar you get this:If you make the busbar extra heavy duty and do like @Ampster suggested with a tap in the middle you should be 'good enough'
For the bus bars, your suggestion of 4 hole and 8 hole bus bars - isn't that what the picture shows or am I missing the picture? Maybe a picture really does speak 1000 words. I used Libre Office Calc (M$ Excel alternative) to create that graphic.For simplicity and to reduce connections I would make up four hole and eight hole bussbars and layout the cells differently in columns. I wish I could draw a picture but it may depend on how much room you have for columns and rows.
Do you think I could use something to polish the silver to retard tarnishing?If you use silver flashed copper, make sure the silver is polished before assembly, The silver tarnish is a lot less conductive than copper or copper Oxide. Presumably, the silver will not tarnish where it is pressed against the terminals (and/or itself), but I can't be sure of that.
Great advice. I'll add that to the list of changes to the diagram.I generally just use the rectangular copper bar from online metals.... It is a lot cheaper.
On the inner 'boxed' busbars, Put the serial bars down first. They are likely to be carying more of the current and therefor should be directly on the cell terminal pad. (The parallel bars will only carry enough current to keep the voltage equalized amoung the parallel cells).
Wow! A lot to digest there. I was looking at some online data regarding how/what to use for bus bars. I couldn't find any quantitative data on using thinner stacks of thinner copper vs thicker cross sections of bus bar. If I use 1/4" for the shorter inter-connects, should I just to 1/2" or will 3/8" work? Based on what I'm seeing at onlinemetals.coms, my only choice for those thicknesses are pure copper.If Possible, I would use heaver duty bus bars on the long 8 hole busbars. This will help prevent voltage changes between the cells. To explain why, the following diagram models the resistance of the bus-bar, the current and voltage drops along the bus bar. (This modeling is a first order approximation. A better model would seperate the copper resistance from the connection resistance to each terminal). As you can see, in this model, the voltage drop across the whole busbar is 16 times the voltage drop between terminal 1 and 2.
The question then becomes: How big does this voltage actually get?
Lets assume that with the connections to the terminal pad and the copper you have .2 mOhm (.0002 ohm) resistance between any two adjacent terminals. Now lets assume you are pulling 100 amp total from the bank. The 100 Amps battery draw would show up between the positive and negative, so in this model 4i=100A. That means i is 25A. Consequently v is .0002ohm x 25A = .005V and the total drop from one end of the bar to the other is 16x.0025=.08V. (The voltage will increase/decrease linearly with current)
Is 0.2mOhm higher than reality? I don't know but .2mOhm is certainly not a large number.
Is .08V a killer? I don't know, but it is certainly getting in the range to think about.
The bottom line is that anything you can do to reduce the resistance on the long bus-bars is important in order to keep the voltage at the cells as similar as possible. Having a single bus-bar instead of stacking 2-hole factory bus-bars is a huge improvement (Far fewer connections). Making the single bus-bar extra thick/wide will help as well.
When you set this up, it would be interesting to put a sensitive voltmeter across the length of the long busbar and see what drop you get under a heavy load.
Makes sense to KISS to keep resistance in check. So it sounds like I should add another hole to the +/- bus bars and use 4/0 all the way to the 250A breaker for "+" (in Conext PDP) and the shunt for "-".I assume the 4x leads are to try to keep things balanced between cells. I would make the 4-hole 'end' busbars extra heavy duty for the same reason I outlined for the 8-hole busbars above. This attacks the problem 'at the source'. However, as my model above shows, it can not totally eliminate it. If you make the busbar extra heavy duty and do like @Ampster suggested with a tap in the middle you should be 'good enough'
Note: see this for making busbars: https://diysolarforum.com/resources/diy-heavy-duty-distribution-bus-bar.71/
If you still want to do the 4 leads, the objective is to make sure the resistance is the same to any single cell, Consequently, you should make sure they are all the same length and bolt down to a heavy duty busbar on the other end. In fact, if your lugs are nice and flat on the top and bottom, you could double up the lugs on two or even one post:
Note: I have never recommended or considered putting 4 large lugs on one post before. I am not even sure I like the idea. It is not considered good practice to have more than a couple of lugs on a post. If you do this, make sure the faces of the lugs sit flat on each other and make a good connection. Also, make sure the bolt on the post fully threads onto the post.
Also, If you go with the 4 leads, don't do individual fuses. The variance on the resistance of each fuse would probably defeat the hole purpose of multiple leads.
No, I was thinking of a staggered alternation of mostly 8 hole buss bars going horizontally but that would require unequal length 4/0 connections at some of the ends where 4 hole buss bars would have to connect to adjacent buss bars. That could introduce some slight different resistance at those connections that might offset the convenience and simplicity of construction. Based on the calculations of @FilterGuy that could be as much as 40 millivolts between each group of four. My BMS can compensate for that but most can't so my simplistic buss bar approach may not be worth it in terms of adding variations between cells. With variations of layout I think that could be eliminated and the only differences might be difference between the side to side versus the end to end terminal hole differences especially if you wanted to run thread rod horizontally between the rows. The advantage of your layout is the 4 buss bars would compensate for the resistance of that extra length between the holes.For the bus bars, your suggestion of 4 hole and 8 hole bus bars - isn't that what the picture shows or am I missing the picture?
I stand corrected!!!For simplicity and to reduce connections I would make up four hole and eight hole bussbars and layout the cells differently in columns. I wish I could draw a picture but it may depend on how much room you have for columns and rows. If you go to this resource and look at any of the figure E diagrams and scale up you may get a picture of what I am saying. https://diysolarforum.com/resources/cell-configurations-for-12v-24v-and-48v-lifepo4-batteries.123/
You sound like you may have more experience than I on integrating CAN BUS messages. I do know that Victron has done an integration with an Orion BMS using a display that speaks translates CAN messages to the Victron proprietary protocol. I seem to recall one other with an Orion. I will look through the forum and see if I can find it.I guess this puts my Conext Battery Monitor on the chopping block. All I need is a CAN or RS485 compatible BMS.
