I'm building 48v system based on 4s Li Time 100ah lifepo4 batteries. I would like to have the possibility to switch off or detach battery from inverter. Something similar to on/off battery switch on Pylontech 48v batteries or some kind of on/off switch or circuit breaker between main battery wires and inverter.
Please could you suggest a real options that I could buy and install suitable for 58(60) VDC system?
I found this option but I'm not sure is this circuit breaker suitable or not? Is it kind of directional or bi-directional?
I saw many suggestions on this forum to avoid circuit breakers as they could be complicated so could you suggest good 60VDC on/off switch preferable with DIN mount.
All 4 batteries will be closed in kinda rack cabinet. Positive wire will have fuse inside rack. But I'm looking for option to make this "rack battery" turnable, to simplify a little bit possibility to maintain, etc.
Thank you!
Thank you!
