fromport
Man you got a lot of solar and components!! I have felt the pain of grid down for 7 day after an ice storm, then nice Sunny days after the storm with micro doing nothing.
That is no fun!
Like I wrote earlier.Thank you for sharing with us your solar set up, and experience's so far!
I really want to feed our micro's into a Megarevo, to charge a small battery . To help off set the peak time our utility has recently imposed.
Next year more battery storage, and hopefully ad a small DC array.
Hopes and dreams......
I think it is best to have the micros connected through a double pole relay.
The relay is powered by the grid and as long as the grid is up, you would like to have the micros connected to your main breaker panel, backfeeding to the grid.
Now you can maximize the PV strings to your MR.
When the grid goes away, the relay looses power, and switches the micros over to the gen input of the MR.
While switching, the micros will loose at least a few cycles so I hope they will go through the 5 minute "scan for grid" phase (they will find the MR generated power) and then start backfeeding.
If the MR should see the extra power coming in, batteries are full, not enough load to get rid of the power of the micros it should use a combination of freq shifting, voltage changes to convince the micros to stop producing full power. If you have older micros (like my Enphase M215) as soon as the frequency will be > 2 Hz difference, they will switch off. If you have iq7/8 micro's they will modulate and start producing less starting at 0.5Hz deviation from the standard frequency.
That would be my goal.
The only problem I can think off is if the relay switches too fast, not proviking the 5 minute timeout.
In that case a time delayed relay should be used with eg 5 second delay between switching status.
Only one way to find out.
