Samsonite801
Solar Wizard
- Oct 15, 2020
- 2,994
Here hehe:
NFPA 70®: National Electrical Code®
<p>90.2(C) Installations Covered.<br /><br />This Code covers the installation and removal of electrical conductors, equipment, and raceways; signaling and communications conductors, equipment, and raceways; and optical fiber cables for the following:<br /><br /> (1) Public and private...www.nfpa.org
I usually just google about specific NEC related concerns... And after years, you start to remember more and more of what you had researched. Basically to start to remember the points that matter most.
Also another hint about NEC, is that it's mostly related to safety, so obvious things are protecting circuits/wires, from overcurrent, meltdown/fire hazards (grounding too). They do offer insights and recommendations as well, like for example with voltage drop, and best practices, but if it's not a safety issue, then it may be a best practice recommendation based on best performance (and not a NEC hard requirement)...
Afterall, NEC is a division of the NFPA (National Fire Protection Association)...
