It’s sized (right now) for winter. I will dump some of the summer excess into electric water heaters and daytime use only mini splits on various outbuildings (not really covered above) for semi climate controlled storage. AC coupled so this should work out well (I think).
I don’t have the second house built as of yet and that will be a couple of years away (barring societal collapse and/or world war between then and now).
Shop might not use much power on a given day or it may use a ton when I fire up a 3-5hp dust collector and wood working machines. Will have independent mini splits for AC only, fridge, couple of freezers, air exchanger. Radiant floor heat powered by wood with propane backup.
My mom’s house won’t draw much. Energy star rated fridge (we just replaced her 25 year old propane unit), smallish TV, couple of higher SEER mini splits (probably two 9,000 BTU units). Stove, dryer, secondary heat are propane. Primary heat is wood.
But yes, I’ve kind of made it modular so I can easily “plug in” more of everything except more total continuous power draw.
I thought about provisioning for a SMA multicluster box for more Sunny Boys, but that introduces more complexities into the system and more risk for a complete system failure should we get a lightning strike.
If I need more continuous power, I’d rather have more independent systems for redundancy..and with a series of transfer switches, I think I could share that power from one chunk to another should one portion have issues.
Plus the multicluster box is $14k. That buys a lot of other stuff.
