Ampster
Renewable Energy Hobbyist
I had previously reported on my Outback Skybox install with a 7kW Enphase micro GT system..
I recently evaluated my needs and the easiest way for me to add incremental capacity is with micros on my west facing roof pitches. For a couple of reasons I decided to upgrade to a SolArk 12k which in reality is only a 9kW inverter. However inverter capacity is not my my need. What I need is more charging capacity for my 42 kWh pack and more AC coupling capacity. The SolArk met those needs and I found a local supplier where I could will call an inverter with no freight charges.
Removing the Skybox was a challenge because it weighes almost 100 lbs but I got it done in half a day and got the SolArk mounted in a few hours. I hooked up the SolArk temporarily so I could charge my battery pack.
Because the SolArk has an option to use the Generator in port for my AC coupled micros that will simplify my connection and free up some breaker spaces on my critical loads panel. I am going to add a small sub panel where my micro circuits come into my building and run a 50 Amp leg direct to the Generator input on the SolArk.
This is a work in progress and I will update as phases get completed.
In the meantime my Skybox is listed at $1800 here:
[SOLD] Outback Skybox $1800 OBO
This is an Outback Skybox Hybrid inverter which is a good way to add battery backup to an existing GT system It can function alone as a GT system and was designed to be grid interactive. I purchased it in 2018 so it has 5 1/2 years of warranty left. The original warranty was ten years. More...
diysolarforum.com
