yash.aungaung
- Dec 17, 2022
- 33
My installer installed solar systems for a home. We are a inverter sell.
At day 1 of installation, the SPD got burned. so he replaced the SPDs. Checked everything is normal. replaced the SPDs again. after 3-4 days, one of the inverter has an issue when grid is on. but it is charging by the grid without any issue when the inverter is switched off. So we told and planned to replaced the inverter the next day. but that night the distribution box got on fire. the smoke started from the SPD (which was replaced one time before). then the whole board got on fire. From that the fire plastic lava drips also caused fire to the battery below too. the inverter on the other hand was working until the parallel cable from inverter got burned. and the battery burnt. we tested if it could be the inverter fault but to our surprise the inverter was doing okay. and the PV reverse voltage from the inverter when PV is not connected is about 40VDC.
So my question is what cause the SPD to burn? the installer said it is the inverter that caused the SPD to catch fire.? I says there might be some irregular spike voltage caused the SPD to burn but since there's no one around, the whole thing catch on fire.
I checked with another installer to see if the wiring was right. He said the way he connected to inverter PV in is wrong which is PV---->SPD----->Fuse----->Breaker----->Inverter PV in (First Pic)
Can the inverter caused the SPD to burn or is the site have some sort of irregular voltage or connection wires?
He keeps insisting the inverter caused the spd burn but that doesn't makes sense to me.
I am attaching the way he installed the PV distribution box. He does the same for all sites. there was never an issue. but this is the first time as well.
0-02-06-cd1c057e19e5923abf9e1b5f524c7ce3782f1bae55b36f96342db2546568ef6d_e9ef5046a79d118e.jpg188.4 KB · Views: 213
0-02-06-a8b2df482379e69ba65dec10c594c3450bf2380eb496c5a8308c953ea8fb8dcf_56e4e1d490b51f4c.jpg307 KB · Views: 215
0-02-06-daa0e653906fcb77c201f6d052c8326d06a3e1560730f9bfcae4d2d32e685629_a606181c3d7d9c5f.jpg406.7 KB · Views: 201
0-02-06-659fd8484983164fe55672cfcdded01cdb51111887a10db2b55dee0675651033_f18c8d6636bdb74f.jpg378.8 KB · Views: 190
0-02-06-39ba7fd41c5f45d4a82fa5aba9ba244ad572c8172beef678286978abcc38d78f_8746202a8e0e331c.jpg392.1 KB · Views: 181
0-02-06-1764d0e95024a9b66dd0aabe7e4d24785a6798bad0382d4a75e072774b49d60a_8c0f1c62d140bd10.jpg316 KB · Views: 189
