Maast
Compulsive Tinkerer
Looks like the inverter I got for $400 was a lot older than I thought. According to Victron support the serial number says it was made in 2006. Be interesting to see how it does when I put some real loads on it.
At any rate, after a lot of manual studying and head scratching I figured out how to change the absorption and float voltages & times using the dip switches - but there's nothing in there about what dip switch selection I'd use to adjust the bulk voltage. It's set for 3.6V per cell which is .5V higher than I'm comfortable with. I'd also like to adjust the low voltage disconnect - it shuts down the inverter at 2.25V per cell which is WAY too low. I can rig a external LVD though so thats not that big of a problem.
I've got another support request email going to Victron but no reply so far.
Anybody have a idea? There are no pots on the mainboard that I see but I can't imagine it's not adjustable when just about everything else is.
The numbers on the board are: 1842012-HEX on the big chip, and
PMP 24/3000
2021070053
06130800006
On the stickers
PMP 24/3000
2021070053
06130800006
On the stickers
