Hi, I was hoping someone could provide some input on selecting a 48V all in one. I have an off-grid property currently running on 12V, and just finished building a 48V seplos battery. My power needs are minimal, but capacity is a big deal as I don't have a lot of PV. I need to run my camper AC occasionally, and also have a 120V shallow well pump. Currently both of these run fine from my 2300W inverter generator, but I do need the surge capacity (3000W) sometimes with the shallow well pump. When it runs initially, I also need to ensure that there are no other loads on the generator. Even then sometimes it trips.
Anyway, I was looking at the Eg4 3000 ehv-48, as it has a 5s 6000W surge, which I think would help. However, I'm still wondering if that is overkill. I don't anticipate ever running the AC off the inverter, so unless the pump is running, I could get away with a much smaller inverter.
I also was looking at growatt models but it seems like EG4 has sort of taken the lead.
