elizabethii
- Jun 3, 2022
- 25
With the recent video from Signature Solar regarding neutral/ground bonding recommendations and my permanent install of 4 3000EHV-48 inverters in process, I'm thinking about how my neutral/ground bond should be configured. It looks like SS's video is specifically in regards to their 6kw units, and they solved the neutral/ground bonding problem through a software change and removing the chassis grounding screw from inside the inverters. At least so far, it doesn't look like an updated firmware has been provided for the 3kw units, and I have 2 v1 units and 2 v2 units. I haven't looked in any of them yet for the presence of the chassis bonding screw.
My incoming power feed is from a main panel that I don't control. In that panel, neutral and ground and bonded together. I get a 4/3 feed with ground. I'm planning on using SBU mode in the inverters, so grid is a last resort or if I overload the inverters. My tentative plan is to bring the incoming feed into a sub-panel where I break out the feed to 4 30-amp 1-pole breakers to feed grid into each inverter. The output of the 4 inverters would feed my main panel with all of my loads. Since I'm getting an already-bonded feed, I would think I want to stay unbonded, but in the event of a grid failure, I'm theoretically unbonded if I were to remove the internal bonding screws.
So, I don't know what methodology I should use to ensure a correct N/G condition. Suggestions are greatly appreciated.
