13kw and 15 KW of solar.
I'm often confused about them, as some write production per day and others count the Wattage of the panels.
13-15kw is /350w about 40 panels yes?
USA is little more expensive, but say 150 for 350 watt poly.
That would cost 6000 USD
Batteries lifepo4 75 for 280Ah plus 35 DDP transport (??)
Make it big 48* , 840ah, +40kwh
Total including BMS 6000 (Daly)
Inverter with MPPT good one, (still China) 10kw or 2* 5kw that fit all you needs (you can choose 3 phase, 230v, split phase...what you plan to use?)
2000 tops.
Some good fuses, cables MC4, and stuff 1000.
Placing on the soil is most easy .
Rack for 40 panels, 1500 should be doable.
1500+1000+2000+6000+6000
16.500 and all is paid for.
Probably cheaper, I kept high prices.
15.000 should be possible also.
Naturally, I'm guessing with the 35ddp per 280Ah battery.
For me it's 18usd.
400A smart Daly BMS is 300 USD, include BT, screen, cable etc. (I calculate 700)
Solar panels, 40 is 2 pallets.
Could be proffitable to get from China, or buy locally.
Again, I'm guessing about the price.
I have heard people pay 115usd for 325 watt panels.
Here I pay 90 for 340w.
if I buy 40 I pay 85 per panel.
Inverter, I have 3*3.2kw, and max 13500 watt solar MPPT (4.500 per unit)
I payed under 1500.
I have no idea what the guys like you to pay for that 30.000...
But..
I've seen local "power wall" (not Tesla) 5kwh for 3500 USD.
Lol. You can make 40kwh under 6.000....
How much power are you planning to use?
Per day?
How much KWh?
For me it's 45kwh without my miner.
The miner uses 24kwh (1000 w 24/7)
All 5 air-conditioning in use.
No restrictions on any usage.
Our water heater is on Gass. Not electric.
To have the same heating power electric I would need 5kw...
Just for hot water in the bathtub/whirlpool.
Sometimes it's good to look at alternative power, like Gass tank and gasoline for generator.
My 6.5 generator is almost double fuel, Gass (LPG) and gasoline.
It is automatically start.
Any generator with starter engine can do this. Just small conversion for the contact.
We do need to work on baffle box to make it silent
If it will kick in, it will be at night...
With the 37.5kwh lifepo4, I don't expect this to be any soon.
But better to have them to need and not have.
If it is possible to cancel the connection to the grid, and you watch some of will's videos (and Mr. Poz / others) on how to build lifepo4 battery..
You could safe so much money and gain freedom.
Solar panels are like Lego.
You can not plug it wrong.
Unless you start cutting things
Depending on your MPPT you have x in series (MPPT voltage difference between 150 and 900 volt, depending on design)
That's 3 or 20 in a serial string
(Calculate with the 40 panels)
My MPPT is in the middle, it starts at 120 and go OK to 450- max 500 v.
I now have sets of 9 panels, 340v but going to change to 3 parallel of 5.
190v, 4500w per MPPT,
I have no special schooling for this.
Original I'm cake- baker and cook
But shifted to software 25 years ago
I like to tinker, cars, motorcycle, electronic, furniture and all in-between.
If you are planning to live off grid, I'm positive that you are "tinkering" minded as well.
You are going to do many things on your own.
If your car doesn't start...
It's a long walk to get help....
So you first try to fix yourself and don't call for help.
No offense to the ones that call for help with dead battery, but if that is your level of self sustainability...
I'm not sure if off grid is good solution
Some people just don't have it. And that is OK, they have other qualities.
My son waits for me or someone else to visit to change lightbulb...
He clearly doesn't have it.
But he can do graphical design... Whow. Really proud of him.
Also coding... He's good.
But don't ask him to fix a flat tire... ?
Seriously, if you can cancel and your reason for off grid is the freedom.
Don't get spooked by the quotations.
Order the 48*280Ah, the 2 pallets of panels and spend the 6 to 10 weeks it takes to arrive to educate yourself via YouTube.
It isn't rocket science!
