Did you ever consider talking to them first before you started posting ?16x Qishou 304 ah Lifepo4 batteries just arrived, i think i got scammed.
They have a weird bump on top. Are these defects important?View attachment 162492View attachment 162493
Not really. I dont expect honesty from people i suspect to be trying to trick me, and i imagine here there are people experienced on this stuff that may have insight on what these pictures reflect.Did you ever consider talking to them first before you started posting ?
What gives you the idea that they are trying to trick you ?Not really. I dont expect honesty from people i suspect to be trying to trick me, and i imagine here there are people experienced on this stuff that may have insight on what these pictures reflect.
I take your comment more as an abrasive response than help and i dont appreciate that.
You sound like you are having a very bad day i would rather not discuss this with you thank youWhat gives you the idea that they are trying to trick you ?
Have had plenty of qishou cells and when shipping or other issue arrive they have always been happy to make it right...
Instead of whining and insinuating common sense and decency would tell you to first contact them and ask them what is up..
And for what it worth, the cells look fine based of the pictures you posted, I suggest you test their capacity and go from there
Thanks, i am going to make capacity test on 4 of them. It takes a very long time to charge them with my small power supply so it will take some days to complete. They arrived at 3,29v all. The internal resistance i cannot check my tester is not sensitive enough. They have a declared 0,25 milliohm internal resistance.No they are not important.
maybe you can capacitytest them all of them
please give us a report on that one
also the ariving voltage
internal resistans
So i just learned that the internal resistance can be measured by the formula (no loaded voltage-loaded voltage)/current.No they are not important.
internal resistans
That sounds about right. I am going to do that nowI found if I series wire 4 cells at a time I charged 4 times faster. Set the power supply at 14.4 . Take the cells off as soon as the current starts falling then parallel wire the cells and finish at 3.65
ok... can i charge one by one without bms and still have warranty?your waranty is now void and nill
use a bms or stop
use a bms or stop
Very very good thread, a lot of useful information in there with pictures, thanks a lot.see this thread, if you see sanding marks around the qr code, then yeah you got had, if NOT then I think you are probably ok. I test report would still be nice to alleviate all fears.
Docan Power bad experience, beware.
Hello! Having read here on this forum a lot of positive feedback about Docan Power decided to buy from them on Alibaba. Ordered 84pcs of Eve LF280K cells from Docan in January. Sales rep was Jenny Wu. Cells were sold as "brand new Grade A". I paid almost USD12K for them, USD141 per cell...diysolarforum.com
