FilterGuy
Solar Engineering Consultant - EG4 and Consumers
OK. Thanks for the update. It is not what I wanted to hear, but at least I know.@FilterGuy
So I originally said yes, from my understanding, since this is what I was told.
I have been looking into the MCU's flash and found today that my understanding was slightly incorrect..
The balance function will only turn on if the charge current is more than 1 amp. The 3.4V cutoff and 25mV difference is correct. As far as duty cycle goes, the MCU enables the balance cycle for 0.6 seconds, then keeps it off for the rest of the second.. in other words, a max of 60% duty cycle. The BQ76920 still has its own duty cycle limitation (70%), but the MCU's is lower for some reason.
With those parameters, the Ballance system is constrained to a fairly narrow window. With the weak balance current, this will make it quite difficult to balance any cell that is not in line with the others.
Is there any chance any of these parameters will be adjustable in a future version of the app.... or is this all 'hard coded' into the hardware?
