"Hello! I need a little support on my new installation. Please see the attached pictures below. The wind speed is gusty at 10 m/s, and the propeller is spinning fast. The diode is flashing strongly, and I measure 10 volts between all phases from the generator. The controller diode "break" is lit, and the charging diode on the controller is flashing weakly. The battery pack is 24V type at 23.3V and is lead-based. There is no DC charging from the controller, and if the battery is disconnected, there is about 10 volts of DC from the controller. Thank you, and best regards."
3 phase wid generator 24 volt 400 W (Marsrock)
24 volt AGM batteries
WT060 12/24V controller
