OK, so my brain is not working very well this morning but, if you have this:8 305p 336ah Trojan flooded batteries 4s2p configuration after a year of using I've learned too small of a battery bank.
Each battery has 336 AH at 6 volts. This would be 2016 WH at 6 volts.
Flooded batteries you should not drain past 50% so now you have 1008 WH available at 6 volts.
You have 8 batteries which you would have 8064 WH at 6 volts.
You are running a 24 volt Inverter, so now you have 2016 WH at 24 volts.
300 watt draw will last only 6.72 hours?
I know its early but is this correct?
