This is for me a single man living in a single wide trailer located in DeRidder, LA. I'm working most of the time and already have a solar pond irrigation system for my garden. So I don't have huge water needs. This will be a completely off grid system. I will be filling a 300 gallon tank using an rps solar submersible pump from the well casing. This is a kit so I'm good with water to the tank. I plan on using a 1h/p jet pump with a 60/40 switch with an 80 gallon pressure tank. To pressure waterline to the house. I'm open to ideas about the most efficient and least power consumption to get water from the tank to my main water line for the house. So, if my jet pump system could be improved I'm all ears.I also don't want to have overkill on my jet pump. I will be pumping on flat ground to about a 25 ft distance give or take from the tank to the main water line. I'm open to suggestions about jet pump sizing as well. I've heard so many different opinions on the amount of power that I need that I'm a little confused. I was wondering if someone could help with the pv array, charge controller, inverter, and battery bank sizing that I would need according to my current not future living conditions to satisfy basically a shower at night and some dishwashing, brushing teeth, washing hands.
