Having gone through many threads on the subject, most agree that in case of a direct lightning strike on ground mounted panels (or even in their close vicinity), there is not much that can be done to save them and that they would most likely be fried.
So if we can't really rely on protection equipment in the extreme event of a lightning striking the panels, would it then be a logical move to at least open the DC breakers during bad weather with thunderstorms and cut the connection between the panels and the inverter, at least saving the latter for sure? Of course it could work the other way around, too. Like if the lightning strikes the house, electrical panel and the inverter, at least there would be no physical connection all the way to the panels, except for the grounding conductor from the electrical panel to the solar panel frames.
