ericfx1984
- Oct 10, 2021
- 741
I was recently contacted by a person in my community who has a small lake cabin that he has ran off of a generator for many years
Apparently word has gotten around my small lake community that I don't have a power pole, and that generally speaking I don't use a generator
I got to speaking with a gentleman and he's interested in having a small off-grid solar power installation done
He wants to be able to run a coffee pot and a fridge slash freezer as well as some 110 volt LED lights... In fact all the loads will be 110 volt
I explained to him that we could skin this cat a few different ways
One option, which I really would not recommend would be a 12 volt system
I explain that we could do an absolute maximum of 3000 watts but that you would pretty much be at the limit of a 12 volt install... Now I know that we can actually build bigger 12 volt systems... But with him having very little experience in this area and not being interested in really learning about it I think a 12 volt system would be foolish...
Furthermore I can't really find any decent 12 volt all in one systems that have inverter, solar charge controller, 110v to DC charger built in
And the fact that without adding multiple charge controllers you're pretty well limited to about 600 Watts of panels makes this seem like it's not a very good option
However... 24 volts opens up several all in one systems, 3000 watt inverter, 60a solar charge controller, 40 amp battery charger. Many of them for less than $500
This would allow 1,500+ watts of panels
And realistically even if I went 12 volts on this build I would likely have a pair of lifepo4 battteries as it would be necessary for the amount of current that he would be likely to draw at times
It seems like the cost of a 24 volt and a 12 volt system would be fairly close... But much more limited on the 12 volt side
Furthermore going up to 48 volts it seems that there are many options for an all-in-one system with only a marginal increase in cost
The only real increase after that is of course the increase in battery
But with this increase in battery cost comes other benefits, one of the most obvious ones being the increase in total battery capacity measured in kilowatt hours
Should I simply tell him, no I will not even plan out a 12 volt system for you... Or should I lay it out and explain that the 12 volt system will likely be about the same cost as the 24 volt system while losing the built-in battery charger and only being able to handle about half of the solar panels
Everybody wants to save a buck I know... But I fear if I build him a 12 volt system it's going to become a maintenance pit where I'm constantly having to monitor it and worse than that he'll be unhappy with the results
Another thing I should mention is he has mentioned that at some point he would like to expand the system to be able to run his 30 amp RV... I suggested that if he went 48 volts... It would be very easy to install another inverter that is dedicated to operating his RV and then it would simply be a matter of installing a pedestal outside of his cabin with the correct hookup
I'd love to hear your guys's thoughts on this... The good news is he didn't even bat an eye when I suggested buying a pallet of 250 w panels from Santan (despite the fact that he likely would not end up using anywhere near all of them)
