FilterGuy
Solar Engineering Consultant - EG4 and Consumers
Do any of you have experience with Progressive Dynamics Lithium battery Chargers?? I was about to purchase a Progressive Dynamics Lithium Charger so I could charge from AC, but when I read the spec, I did not see anything about charge profile... All I could find was the output voltage. I contacted the company about it with this exchange:
Beware of that last line..... You can't leave those 'chargers' plugged in permanently. They are just fixed voltage power supplies!
I have decided to look elsewhere for a lithium charger. I am curious what others think?
Me:
I am looking at your PD9100L line of lithium chargers and I do not see anything about multi-stage charge profiles.
It appears from the spec to be a fixed voltage supply. Could you please let me know what the charge profile is with these units?
Andy Giesen from Progressive Dynamics:
Our lithium chargers have a constant voltage output….these are not multi-stage.
Me:
Is that OK for the lithium batteries? Shouldn't the voltage be turned off or at least dropped when the charge is complete?
We worked with battle born batteries while designing this unit.
They told us that the charger should not be left on for more than 2-3 weeks once the battery is charged.
If you are a dry camper and use a generator to charge, then the unit will only be on for a few hours at a time.
If you are constantly plugged in, then you may need to periodically shut the converter off for a while
