2.45v cell voltage is just normal absorb charge voltage. Equalization is about 2.60v per cell. Discharging first gives greater initial recharge current which helps recharging not totally hardened crystals. The initial recharge current will fizzle out quickly if battery is sulfated. If you repeat the discharge/recharge many times you may gain a slight amount of capacity, but not usually much.I put the wrong link at the beginning, I'll put the right one when I find it.
Tests had been done on it by draining the battery and charging it to 2.45 voltage + 1 day of 2.45 overcharging, after which the battery was again drained and charged in the correct direction. Mechanically undamaged batteries could be returned to almost new condition. This does not work for Pb-ca batteries.
Flooded lead acid only. AGM and others would probably vent electrolyte.Have you tried it on a gel battery?
Have you met modern day PHDs?I cannot believe someone would actually submit a PhD thesis just regurgitating info that has been known for 100 years on lead acid batteries. I see no claims of new information in the paper. A PhD thesis is supposed to show some innovation.
I read this post the first time around, but upon reading a second time im reminded of a few things:make a fast high current battery charger. They claimed if you periodically did a short high current discharge that bubbles on the plated would collapse.
I tried reverse charging once, the battery still had enough voltage it fried the charger. I tried putting the smoke back in the charger but I guess I didn't blow hard enough.Small update. The battery has now been used alongside others and it works fine now. The resting voltage is a little lower and I suspect that the sq is a little lower than the others. I haven't added acid yet because it's a gel battery.
At worst, I got only 60Ah from a 330ah battery. after reverse charging the first cycle was 280Ah. This apparently works when you do it properly, I wouldn't have believed it. Next, I will test this on an 80ah car battery, whose capacity is only 12ah. EDTA, pulsing, desulphator have also been tried.
