I have installed my Growatt 6kw, 12 500W moncrystalline panels and 2 Rosen 200amp hour batteries in January 2022. The system is running fine and no issues at all with the amount of amps/volts supplied to the inverter. My problem is since January when the batteries were installed they charged from SOC 49% to 96% no problem in approx. 5 hrs. As each day pass's the SOC drops 2% and my Amp/hrs drop 2amp hrs. It is now March 17th and my SOC 66.66% and amp/hrs 133.16 after a full day of charging. Actually they stop charging around 11 am as the Y warning comes on both batteries. The warning is OV-warning which is over voltage according to the manual.
I have contacted Rosen and they were able to reprogram Bat 2 and it showed 196 amp/hrs after doing this update through my computer. However since then last week the same problem is happening, it is loosing 2 amp/hrs a day and SOC dropping. Bat 1 they could not update through my computer and waiting for them to figure that out. My concern and question is why are these loosing SOC and amp/hrs since new.
Bat one is only at SOC 33% at 7am and at this rate it will shut down at 20% which isn't going to be long from now. I am not using AC units at the moment but summer is coming. My peak amp draw per day is 28.6 amps and average 18.3 amps. Thanks if someone can help, I live in Mexico and am totally off grid and totally isolated from major centers.
