I would not rely on MDF alone to compress my cells. Many of us are using threaded rod with 3/4" plywood on the end for the compression frame.
Yea. Going to get some plywood tonight. At least I already have all the measurements.I would not rely on MDF alone to compress my cells. Many of us are using threaded rod with 3/4" plywood on the end for the compression frame.
I have already installed my Victron 3000 inverter/charger. I may move it depending on where I install my battery bank.
The Cerbo came with a temp sensor that will be utilized. I also have the Bluetooth dongle for the MP. Thought about using it to monitor the temperature of the MP.Welcome to the redonculous 5th wheel club.
Make sure to use the temperature sensor for that multiplus with the pack.
What BMS are you using? I didn't see any notes there.
Look up Victron's spec for your main fuse. For my 24v, it's a 350a. Use beastly wires for that multi at 12v.
Finally, You need a pre-charge circuit.
It has sufficient cooling but I will be moving it and it will have even more ventilation.This looks really cool, but I have to ask:
Is the compartment behind the panel "well ventilated"?
Is there 10cm of clearance on all sides of the unit?
Those are the criteria for installation in the manual.
Even if the area above the panel is open allowing access/ventilation behind the unit, I would still feel compelled to cut some vent slots below and to the sides.
I have that also. Wanted the bluetooth to connect to the app.To config the multiplus you'll need a usb mk3, the Bluetooth interface doesn't let you get into the major settings
I have a 400A main fuse per manual and 4/0 wire. Manual spec. For wire is 2 x 40mmsq. I should be good with the 4/0.Welcome to the redonculous 5th wheel club.
Forgive my interruption. About the pre-charger, if you have the main battery cable on a DC breaker (in my case a 200amp breaker for my 24v system) and you switch the breaker off before connecting the battery, then connect the battery and turn on the breaker, do you need the resister? If yes, Where does the arch occur when you turn on the breaker?
