Zwy
Emperor Of Solar
I don't really know what type of pump controller. it's a Franklin Electric Pumptec controller.. There's a big capacitor inside the box.
Basically just a pump controller with a capacitor to provide the 3rd phase to kick the 3 phase pump spinning. This will have a high starting surge for a few milliseconds, just like all the 3 phase pumps. Running is 7A load, I would think the initial current surge would be 28A or less for a few milliseconds.
Tank float switch in water tank that is currently connected to a 2 pole 240V contactor with a 120V control coil. (I've just ordered a 240V control coil contactor to not rely on the grid). I also still have pressure switch as a back up in case something happens to the water tank, I can shut off water to the storage tank and pressurize the pipe from the well pump again.
Looks like you have that figured out.
I had a pair of MC4 connectors with about a 6 inch long wire that I clipped off the retainer locks so I could easily plug into a connector and disconnect. Do not touch both wires at the same time and keep the leads short so the ends can't get close enough to arc. Ensure the multimeter is rated for the voltage you will be working with.New issue today: I connected 5 (395W, 48Voc) solar panels in series, installed all the mc4 connectors, high-voltage disconnect to the Growatt. The Growatt doesn't show any solar pv array connected to it. I wasn't sure how safe it is to check connectivity on a series of PVs? I'm planning to go check the continuity after sundown.
I checked polarity on each panel first, wrote on the backside of the panel whether a wire was + or- when the sun was shining. Then compared the polarity to the connector. Each panel VOC was the same. Series connected 8 panels that have a VOC of 49.5V and then checked the VOC of the connected string, right at the 400V level.
Next, ran pv wire to control panel on array that contains IMO disconnect switch, breakers and surge protectors and checked open circuit voltage there. Then to the IMO disconnect switch inside the house at the inverters. Noting polarity at each step plus the pairing of wires is correct.
I prefer checking as I go along, eliminates problems such as open circuits, reversed polarity and determining if resistance is present with 2 strings to compare against each other.
