Koldsimer
- Dec 4, 2021
- 604
I am using equal length 2 gauge wire to hook each of my four batteries to the rack that Signature sells. They are all hooked to a common busbar.I can't recall if you covered this earlier in the thread and I didn't get a good view of your EG4 bank wiring in your video, but would you mind detailing how they're wired?
What wiring is the same when you use other batteries and what wiring is different?
I have a 10' 4/0 cable that is wired to my inverter and i have been switching it from bank to bank to turn on inverter. It is the same cable used in all attempts.
Concerning the batteries, i have tried them all individually and in every possible combination with the same result. I have tried them connected via the 485 cable, not connected etc. Same result.
I made sure all connections are tight and clean several times early on.
