Checkthisout
Solar Wizard
- Nov 14, 2021
- 4,810
“So I figure a container designed for 61,000 lbs gross weight can probably handle being supported by just its corners, or almost any point, when empty and only 10,000 lbs.”
Not sure this is correct. There is a lot of engineering in there. Corners are designed for load. Web not so much. Can fail, warp, twist if not loaded as intended.
What do you mean? Do you deal with containers often? Built anything out of one?
