crossy
You have the settings correct, General Lithium on the inverter and Sofar Can on the BMS. Good work btw
The only issue I can see there, is you have tied your active balancer leads in to the same single cable run as the BMS sense/balance leads.
This will cause you issues and throw random BMS warnings, had the same idea and it started to give issues.
Yeah, that arrangement of the balance leads isn't ideal, it's historical (and I was too lazy to change it). It did behave ok with the old Daly BMS so let's see how we do with the Seplos.
The cells are (well) used golf-cart units due to budget constraints so that active beast is definitely needed.
