Very useful; I’ll try the constant voltage charge tomorrow; I just need to disable ‘total voltage overvoltage protection’, right?
If I also disable ‘monomer over voltage protection’, will the voltage to be kept constant remain the total one or the one of the highest cell? If it’s the latter and equalisation is turned on, then this would effectively be a top balancing (i.e. the balance current would match the total pack current for the highest cell to stay at a constant voltage)
Not the protection, the warnings (alarms) for cell/pack high voltage. Warning threshold is the one that triggers 10A charging. If you disable the warnings the charging will be voltage based and the voltage is set by the pack over voltage protection setting.
Let me give the exact parameters:
The "
Monomer high voltage alarm" and "
Total pressure high pressure alarm" set the voltage at which the charging goes in 10A constant current mode. These can be disabled on the right and the charging will be only in CV mode. When these voltages are reached the SOC is set to 98.2%. Even if the settings on the right are disabled.
The "
Total_voltage overvoltage protection" sets the charging voltage. If the protection is enabled on the right once that voltage is reached the BMS will turn off the charging MOSFETs. If it is disabled the MOSFETs will stay turned on. This is useful if an inverter is having issues due to the MOSFETs being turned off.
The "
Interval charge capacity" that is expected to disable charging until SOC falls below specific value seems to be not working in my case. Most likely it needs enabled "
Total_voltage overvoltage protection" to disable the charging MOSFETs and in my case this doesn't work (the SMA Sunny Island logs error whenever the charging MOSFETs are switched off).
And I've confirmed that the 100% SOC can be set without switching off the charge MOSFETs for the 10E. One attempt to charge to higher voltage (56.1V) resulted in 100% SOC being set while still charging with 10A and the voltage of the pack being 56.06V. But this had no effect on what happened after that - the charging continued the same way - with minor charge/discharge cycles after that. I was hoping that once SOC gets at 100% the BMS will ask the inverter to stop charging and ask it to start charging again once the SOC gets below the "
Interval charge capacity". But I was left only with hopes.
The more I get in the BMS, the more I realize what is the problem with it - the lack of documentation. The horrible Battery Monitor translation is almost bearable. But the complexity introduced by the complex functionality and the lack of documentation is something that I would consider as a no-go if these were known before I purchased it.
So my latest settings are:
Monomer high voltage alarm: 3.4V (alarm disabled in the settings on the right)
* Monomer overvoltage protection: 3.6V
* Total pressure high pressure alarm: 54.4V (alarm disabled in the settings on the right)
* Total voltage overvoltage protection: 54.4V (protection disabled in the settings on the right)
This way the pack charges to 3.4V per cell in CV mode set to 54.4V, does not disconnect the charging MOSFETs, but keeps the pack at 3.4V until the sun goes down and the inverter had to get energy from the battery.
The common perception seems to be that a pack kept at 100% SOC will degrade faster and this is something I would like to avoid, but there just seems to be no option for that with the Seplos BMS and the SMA Sunny Island inverter. This is why I went for 3.4V instead of 3.45V. To keep the pack floating at a bit lower voltage.
