I definitely think you are on the right track. I was being very general, and i agree your ACTUAL measured consumption and the nature of the loads makes your setup a little easier. Sorry if my post came across as doubting you. I think youve got a handle on it.
Not at all sir. I value your opinion and knowledge. I'm getting a much better understanding of how to size a system now. In my mind I was thinking cover the day load and a little extra to charge just enough battery to get me through the darkness each day. But that's not so cut and dry. At first I was figuring for covering the 206 combined watts with solar during the day and some extra watts to charge the 2x 12v80ah batteries from the night before. It really blew my mind (if my calculations are right) that in reality it takes 800 watts of panel to do that. I mean it's just 206 watts right? In 1985 I had a 200w Roadmaster EQ in my car playing Bonjovi Lol! I was a bad ass and didn't know it with my static-matic and didn't know it was really a 800 watt ?
All jokes aside I started learning with my own research a little bit and the math I was being told to do just seamed so over board for something so small.
In my ignorance I was thinking I could just cover the total running watts per day and a little fat left to charge the two batteries and compensate (some) for a little cloud cover. For what my tests for use is I really don't use much during darkness so I would not have to put that much back in. The two batteries should give me at 50% drain 4.66 hours nightly at 206 watts being they are lead acid deep cycle. Since they run very little at night I was confident there would be extra to compensate for starting power in those 960wh. So that led me to think like a grid tied person I guess.
It seems to me the rule of thumb figures are a cover all. One size fits all but every situation isn't the same. I didn't realize solar was so iron clad. No flexibility. As in it's this or nothing which is disappointing to me if that's the case.
My calculations seems reasonable to me at least in the beginning looking into this.
400w x 4hrs = 1600 watts daily production.
So 1600w - 200w running load = 1400w left while running to charge the batteries back up.
160ah pack x .10 = 16 charge amps
80ah (used over night max) ÷ 16 = 5hrs if drained to 50%
You see in my mind I know that at least 90% of my 2.3kwh 24hr total is consumed during the day as I have ran test in many various times frames. 24hrs but also taking numbers during specific times of day as well as night. Even during peek hours to know about what they would draw during my honey spot hours for max charge capabilities.
Me also knowing 4 hours isn't the only solar I will be getting. They may not be peek performance number but there are numbers. Solar panels aren't union workers so in my mind I am thinking about the rest of the days production playing a part as well. 400whs? I have no idea yet but it's going to produce something right? Where my array will be the sun will hit them from east beginning at sunrise. From the west they will be hit with light until sunset. They will never be shaded until clouds or darkness occurs.
long story short my overnight demands are very low. That's to say 400 to 500whrs.
so long story short I figured if starting amps were covered by the battery and there are only a couple starts per day for the freezers they normally only draw the 206 watts combined. I see now that 400 watts of solar are in reality 320 per hour usable at best. So no that's probably cutting it too close. 600? Y'all would know better than I would.
I'm not looking for any more than it takes to run them during the day at this point and bank up 500 for the night. I have grid so big deal if it's cloudy the next day. One day I'd like to grow to an off grid system that never pulls from the grid with all certainty possible but that doesn't have to happen right now. I'm not miles from the grid. Far from it. I have 380amp service. I installed two 200amp panels years ago.
90 percent of my DC current knowledge come from a very long mechanic background. My A/C knowledge comes from my military MOS. 51R (interior electrician). Solar knowledge is very limited in comparison to both but knowledge of both has helped but not as much as you guys here have helped me. In my search I read MANY hours and lots of that was in forums. I'm not kissing butt by saying I chose this forum for two reasons. One being it seemed it was full of knowledgeable people willing to help others. Two people like me were treated with respect and kindness. I chose the right place. So many are ugly to the ignorant in other forums but this one, this one is a great place to learn from new friends. Those kinds of things I really appreciate in people.
I'm on somewhat of a budget since my first step was to eliminate the power hungry old appliances. That set me back nearly 600 bucks but we did down size or it would have been much higher.
I thought about doing a mini-system for each appliance but then is that cost effective? Probably not I have not really checked. Do you think so? The mini fridge only has a few condiments in it and beverages. Canned sodas and sweet tea. I drink a lot of tea lol
also it's heaviest use is from 2 or 3 until around 6 on weekdays and weekends double time because we are home all day. It's getting cooler here at night now so the overnight running should reduce quite a bit as the appliances are not in a climate controlled environment. We have pretty mild winters but in it's peek usually (freezing temps) 30 degrees are considered extremely cold but 40 to 45 is normal for overnight.
I'm contemplating getting one 100w panel, a charge controller and the inverter I'm looking at and set it up with one of my 12v80ah batteries and see really what it does since it cycles more than the freezers by a mile. Your thoughts? I can use the inverter to grow on with a larger controller later?
To me this inverter
https://us.ampinvt.com/products/pur...-dc-12v-to-ac-120v-output-with-hd-lcd-display
is a prime candidate for the job but you may see an issue I do not.
If you have the time I'm grateful if you spend any of it helping me and surely want others guidance. I'm rambling but that's pretty much all I want to do. Power this lil load and charge the battery for another night of 500w use.
The way I'm thinking isn't reality I guess.
Thanks a bunch in advance and have a great day!
