Yep. Generator= peace of mindYeah I read a saying on here once, when the sun is shining you have too much power with solar, when the sun isn't shining you can't out panel the clouds. They win!
This is true, i've came to the conclusion that the best money I can "spend" is just running the genny periodically from october - January. so be it, first time I had to run the genny since last christmas was yesterday ! :D
That's why I like the idea of making compressed hydrogen using excess solar, but the stuff sure isn't easy to store long term. Maybe some sort of algea based bio fuel instead. Something other than batteries for long term, non reusable storage of collected solar energy.
Are more batteries really cheaper? I’ve wondered about that. For winter where I am, there are some days were I have excess solar and I could charge beyond my current battery bank, but those days aren’t many in deep winter. A thousand dollars for more batteries, for example, would buy a lot of gasoline/diesel for my generator for the few days that I would need it. Plus I can use the extra diesel in my tractor in spring if I don’t use it. (I’m 100% off grid)Still the cheapest way to store power is on the grid, if its available. The next cheapest way to store solar is with a DIY lifepo4 battery bank!
What's "Mowing" ? I lived in VA and NC for the first part of my life. Two things I can honestly say I don't miss: Mowing and raking leaves / pine needles. My only question is why do people move to the desert and think they need to have all this east coast vegetation that likes to blow into my yard?I'm too cheap for those. lol
More panels = less mowing. It's a win win.
I hate pine trees. One missed my house by about a foot during a hurricaine in NC. Pine needles suck, and are annoying to rake. Pine cone pieces hurt when you step on them in bare feet. YMMV. I cleared about 10 off a 1/2 acre lot after that. Felled it myself, climb, rope notch, pull and go. Not too bad, I was sawing about 15 feet up. How tall?I've spent the day watching robot tree cutter videos. I'm about to declare war on a few monster size pine trees.
Winter is coming and those suckers are getting to close to my panels with the shadows they are casting.....
60 to 80 feet I think. Way to large to just cut down on my own and not hit something and at $5000 a tree to have them removed I can build a heck of a robotI hate pine trees. One missed my house by about a foot during a hurricaine in NC. Pine needles suck, and are annoying to rake. Pine cone pieces hurt when you step on them in bare feet. YMMV. I cleared about 10 off a 1/2 acre lot after that. Felled it myself, climb, rope notch, pull and go. Not too bad, I was sawing about 15 feet up. How tall?
Well you could use the leccy to crack water into raw hydrogen, but bulk storage does require tremendous pressure. Is there a way to turn electricity into a different volatile, perhaps liquid? I considered a solar still at one point, but then you have to create a mash, and ... Algea has the same underlying problem of vats and real estate. Pumping water up and gravity, but you are back to the real estate problems.That's why I like the idea of making compressed hydrogen using excess solar, but the stuff sure isn't easy to store long term. Maybe some sort of algea based bio fuel instead. Something other than batteries for long term, non reusable storage of collected solar energy.
I assumed we were discussing off-grid energy solutions. Yes, the grid is the cheapest way to have "unlimited" storage. Batteries are certainly the simplest and cheapest currently available method of storing off-grid solar for later. I was just dreaming of an off grid renewable resource.Still the cheapest way to store power is on the grid, if its available. The next cheapest way to store solar is with a DIY lifepo4 battery bank!
Haven't built the ground mount yet. But, it will be wood on concrete piers.I think you said you built your ground mounts with wood. Did you cement the posts or just bury them?
Have you looked at a biodigester ? you could heat with excess energy , biogas can be used like propane , it can be pressurised into cylinder if your brave
I've looked at the biodigesters. They are pretty neat.
I've even seen people manage to get generators running on biogas, but it's a PITA.
I also only have so much compatible waste to give it.
Perhaps in terms of Gas vs. Solar per kw, yes..But my generator can power me if my inverter fails or a tree hits my array. I already have more panels and battery than I need 90% of the year.Yikes, sometimes math is not fun haha
If you are willing to climb & rope it's not that bad, a little scary. Attach the rope up high and anchor it. Depends on what you can manage for a fall area, as you top it. If you have a 40' fall area, it's just patience. $5K seems like a lot.60 to 80 feet I think. Way to large to just cut down on my own and not hit something and at $5000 a tree to have them removed I can build a heck of a robot
I loath pine trees to but these monsters were here when I bought the place.
have you seen cody's algae panel experiment?That's why I like the idea of making compressed hydrogen using excess solar, but the stuff sure isn't easy to store long term. Maybe some sort of algea based bio fuel instead. Something other than batteries for long term, non reusable storage of collected solar energy.
