Nope, but he did warn to be careful with adding more stuff to the system and having the SD card write more than it should possibly breaking the card.
Now that I opened up a somewhat informal channel with him, I hope to persuade him more to update the shipped version of Grafana to a newer one and maybe allow people to make their own charts. The original one is not in the database, it's in a hard coded JSON so there is no chance of messing that one up even if he granted grafana use access. The problem is that you can't log into Grafana when you're accessing it via Solar Assistant, you have to do it on the native/direct port which is locked down to only allow access on localhost by default.
I also mentioned the logs on ramdisk not logrotating
