Ampster
Renewable Energy Hobbyist
There is a function to have Solar Assistant calculate SOC using current data from the inverter. It is a better estimate than the SolArk. It is called BMS emulation. It might work with multiple packs but only in aggregate. Without communications with each pack, it would not be able tell you if one pack is a problem.Solar Assistant is BMS emulation to the inverter.
