Zwy
Emperor Of Solar
I am currently remodeling other areas of the shop so I've got some time as the PV and HVAC industry seem to be rapidly evolving. My top 3 choices for replacing this mini split are as follows.
1. Cheap Pioneer (or one of the clones) with a good warranty, wifi, good low temp heating performance. The 120v 12,000Btu units are crazy cheap these days around $700-$800 and would be easy to run off an inverter.
I run a 12K Pioneer floor mount. Very little power draw. I prefer 240V simply to keep loads on inverters balanced plus SEER/COP is better.
I do have a 120V unit for my truck camper. That only has the one inverter.
2. EG4 12k hybrid solar mini split. I really like the idea that a couple panels can panel this unit without the grid or a inverter. The app and wifi look great. Line set is too short and its a lot more expensive than the Pioneer.
Some issues with the EG4 seem to be clouds can cause the unit to shutdown and not restart. It will switch to AC power if you have AC hooked up but it seems the unit has over a 100W standby draw with AC connected.
My Pioneer when running during the day might only draw 300W.
Hotspot 12K BTU compared to a Pioneer 12K BTU3. Hotspot 12 or 15k. I've almost ruled this one out due to price and performance.
Hotspot cooling COP is 5.65 (Hotspot rounded up)
Pioneer 240V cooling COP is 6.00
About a 8% difference. Of course, if battery bank and PV are large enough, it probably isn't a factor with long summer days.
I noticed a heating COP of 3.69 listed on the Hotspot and for the Pioneer it is 3.23. Somebody is fudging numbers as HSPF for the Hotspot is 9.6 and the Pioneer is 10. If you multiply HSPF times 0.293, you will see the Hotspot is 2.8 for heating COP and the Pioneer is 2.9
