One topic that seems to be rarely discussed is bypassing the inverter at overload. I understand ATS - that switching algorithm is based on battery voltage. My question is about infrequent overload (outgoing Amps) of the inverter for some minutes (not just a surge).
Will mentioned in one of his videos that the AIO units (his example MPP) switch to grid power in case of overload. How is this done with Tier-1 inverters such as Samlex or Victron?
Why would I want to do this? It's a simple utilization argument. Typically people are encouraged to choose a power inverter that is one step above of what the calculated need is. But what actually defines the "need" in an off-grid situation? Assume I hook up a bunch of devices that come on and off - fridge, microwave, toaster, laptop charging. The average is always much lower than the peak (which determines the size of the inverter).
Example: If I build a small off-grid system with 2kW solar to supplement (!) my grid power usage, and my average load is 1500W and once in a while I jump over 2000W for a few minutes per day, it makes no sense (to me) to buy a 3000W instead of a 2000W inverter, given its higher idle load and higher price. I will use grid power anyway when my ~2kW*4h=8kWh solar energy is used up. So switching over in those rare cases when I need say 2.7kW for a moment does not change my daily energy budget. On the contrary, I can hook up enough devices to make sure I actually use up the 8kWh without worrying about overload.
My question is: What is the best cost-effective way to allow the inverter or system to switch over to grid power in case of overload instead of shutting down the inverter? Maybe it's a silly question since I don't find much discussion of that sort (tell me if it is ;-) )
