Not necessarily,…That is true everything on leg one will see 140v.
I got lucky when I tested this and the breaker was on the lower leg. I read 89v one and 149v on the other. Inverter two had a board/nuetral issued when I first installed and it sent 220v down one leg.Not necessarily,…
I’ve seen some get riV, some get 177v etc… without the balancing conductor, it depends on what is running and connected.
Turn on a toaster, and a fridge could get 208V, or 60… it depends on what is balancing the conductor, the grounding earth continuity, etc… it’s a crapshoot, not a formula.
My wife wanted to heat our 17000 gallon pool free. She tried propane, heat pump and they were too expensive. So I took on the project and last summer the pool was 92 f with no cost. Well we did run the pool pump but that was it. This summer the solar panels and Inverter should easily cover the pool pump.Appreciate the thoughts on improvements.
It seems like the SCCs and maybe the Inverters are going offline for some reason. And then the other the issue was something to do with charging the batteries using grid power with the Inverters. I found that puzzling.
Just one of the inverters is doing a quick reset, I have looked for a pattern based on what is being used but not seen one.
I never use the grid to charge my batteries because it seems like a waste of energy. The Inverter loses a bit of power and probably the wiring so If I used the grid to charge my batteries so I could use my Inverter it would just not make sense to me sense it would burn more power from the grid.
This winter late December through January, we had weeks of just clouds, it was impossible to keep charged. Never seen just week after week of cloudy days that I can remember.
Maybe I just read it wrong. My system does not need resetting and when the batteries are not able to run the house due to low battery voltage then it automatically switches to the Grid. I would be frustrated to have a sunny day go by and have my system offline because I was gone and did not reset it.
My inverters will not switch to grid, but can use grid to charge. I’m adding more panels and scc but even then if next December/feb is the same it will marginally help.
Another thing that you may consider is solar hot water panels. They work wonderful for me. With the sun I can get 150 f on a 80 gallon tank. The tank has to be indirect due to the antifreeze running in the solar system.
I had looked into those but was just unsure about them. We use a lot of hot water due to our job. After the terrible time with the one Rheem I put two in parallel just in case one goes down. Love to do a diy pool and use solar or solar water heater.
I bookmarked your reply, I will have to research this some more. I have cut out so much with upgrades but we can still hit 70kw during the winter months when its hardest to make it back. I will probally stop with one more bank after the next set of panels are up.My wife wanted to heat our 17000 gallon pool free. She tried propane, heat pump and they were too expensive. So I took on the project and last summer the pool was 92 f with no cost. Well we did run the pool pump but that was it. This summer the solar panels and Inverter should easily cover the pool pump.
The system is totally automated. When it gets hot on the SE side of the roof then the pump turns on and pumps water through 3000 feet of black 1/2" tubing that is next to the hot metal roof and back to the pool. When the SW side get warm then a valve switches and the water is pumped through an additional 3000 feet of tubing back to the pool.
Last summer I added an additional 10 4' x 8' hot water panels to the setup. We also installed a wood boiler to help. We burn wood to heat the house. I am busy cutting and splitting most of the summer to get the 9 cord necessary.
The wood also supplies 100% of the hot water demands when the solar is not adequate.
There seems to be an abundance of hot water panels around. People will put them on the roof and then take them down to have the roof reshingled.
My system is not anywhere as big as yours. I am running 24 panels and 2 Charge controllers, a 4400 watt inverter and 32 Lifepo4 cells configured into 16S-2P with 2 BMS.
My wife wanted to cut our CMP bill and provide some security when the Grid is down. This time of year we are doing about 30Kw per day or less once the cells get charged then the power tapers off. The Cells last the night but if we do not get sun the next day then it switches to the Grid.
Most sunny days the
