thepartyhound
Christian Prepper
- Sep 14, 2022
- 94
I had plans to purchase an EG4 system for an off grid cabin in the mountains. I was just about to pull the trigger on what I needed when I started looking around at all of the negative feedback in reguards to SS after sale support. Also, it seems a lot of people were having problems with their EG4 units. I really wanted to convince myself that this had more to do with user error than any actual problems with the hardware/firmware because the EG4 does appear to be one helluva bargain!
As much as I like a good deal, however, I don't want to end up in a position where I'm having problems and am unable to get the support needed to get it fixed due to the remote location and complete lack of cell service at the location. I need something that as long as I do my part it will just work. Victron seems like it might fit that bill.
One thing I like about the AIO EG4 is that it seemed very simple, beginner friendly. Victron does not seem to be aimed at beginners. It does not sound like a cheap made-in-communist-china kind of unit and I like that a lot more!
To start with, my system will be pretty small. I'm thinking I like the 5kW 48V Quattro inverter. I plan to use one of these to start with. I will use a 2.3kW PV array consisting of (10) 230 watt panels fed into a 150/70 smart MPPT. This part of the system I think I understand pretty clear.
Their "shunt" I am not so clear on. I plan on using their Lynx shunt and Lynx distributor. Along with these items, I have planned on using the Cerbo GX kit (touch screen included).
I do have some questions:
1) As a bare minimum system do I have to use the shunt, distributor, and Cerbo GX? Is there a less expensive way to accomplish the tasks handled by these units?
2) I had planned to use (2) 48v 100Ah Trophy batteries to start with. Will these communicate with the inverter, or do they even need to?
3) I plan to make this purchase through CurrentConnected. I have not seen any bad info on these guys and it seems a good idea to avoid SS for the reasons mentioned above. Is CC a good choice for a vendor? Are there any other better suggestions for a vendor?
4) From my understanding the Victron unit does not suffer from the same problems with using a generator that an EG4 does. Is my understanding correct? I had planned to use the EG4 chargeverter when I was still looking at the EG4 AIO system, but this should not be needed with the Victron, correct?
5) Will the MPPT I have mentioned above be large enough for the 10 panels I plan to use?
