Micah123456
- Jun 29, 2022
- 50
I have this issue where in the middle of the night the lights start flickering, ups starts beeping as the inverter starts seeing voltage sags. Running eg4 3kw inverter with one 5kwh egyll battery right now. See image, right around 4:33 i switched back to grid because my office UPS kept beeping sensing problem with the AC. The voltage sages down to 115, 114 volts. Note that for the 3kw inverter the load is not high, inverter 1 in both cases sags but is only seeing 600 watts on it. the battery would be at 55% or something at that point, so not low really. Wondering why its having trouble keeping the ac output steady. I don't think i have any big loads that its just not showing, ie big spikes. Any ideas or experience? Does a bigger battery bank help here to even out sags or is there a response time to loads the inverter has to catch up with?
