All true in a standard system.Attached is a good video on A/C oil air/moisture absorption. It comes out but can take a very long time to accomplish.
A/C techs cannot afford to sit around for several hours waiting to achieve proper microns of vacuum. Time vs. money says use it once (from a metal oil container) and throw the rest away. Avoid buying oil sold in plastic bottles. Avoid gallon jugs. Plastic does not provide a good hermetic seal.
When a compressor is changed you have to analyze how the old compressor failed.
A compressor motor burn out will cook the oil causing contaminates in oil with acids that will harm system. Need to flush and/or acid neutralize system. Common practice, short of full system flush, is to place an acid neutralizing suction line filter prior to new compressor suction line input, then come back in 7-10 days and replace the filter with a new one that is left in system.
A compressor that fails for poor compression can leave excess oil in evaporator. When new compressor is installed the oil comes back to new compressor resulting in too much oil. Can cause hard starts on compressor and reduced system efficiency due to excessive oil coating in tubing walls of condenser and evaporator.
Should also change high pressure liquid line filter. It may be hidden between outside grill and condenser within outside unit.
On a normal run system. The original factory compressor oil sump load of oil will distribute 8-10% into system (mostly in evaporator), and 1-3% gets wicked into motor stator wire winding. Some of the oil wicked in motor windings dips back to oil sump during off rest period of compressor.
In a minisplit, it’s nigh impossible…
