Almost lost me at making digital currency mining part of the ROI.
Instead, I'll just buy the "how to play blackjack" pamphlet in the lobby of McCarren airport and move to my island in the bahamas.
My concern is that I see a shift going on - what started out as trying to hold manufacturers to the bar by exposing sub-standard parts, engineering (like low-temp sensors) and techniques, that substandard is now ok - the justification being that they are so cheap to get and replace as an alternative to using quality parts with manufacturers that might actually be around in 10 years.
Using quality manufacturers and products should be the only thing you base ROI on.
He'll learn. When you buy junk what happens is two things:
1) You simply buy the same junk over again. ROI lessens.
2) You buy the GOOD stuff up front, which is less costly than the above. ROI improves.
Unfortunately, most of what I see here is "what's the cheapest xxxx", and the results of that either come later, or the disappointed user is never seen again in the forum..
