hwy17
Anti-Solar Enthusiast
On what basis are you concluding this? Are you looking at the Pytes study? 143m3 minimum installation room!the amount of gas that a 16s pack could put out is barely enough for the cubic meters
only in a sealed container. I have about 30 gallons in stainless steel jerry cans that i rotate every 3 months due to earthquakes and lack of fuel when they happen...How do you feel about storing gasoline in conex boxes?
yes I read it just like you did.On what basis are you concluding this? Are you looking at the Pytes study?
The room pictured is smaller than 143m3, much smaller.yes I read it just like you did.
Not a good idea. But I see your approach.only in a sealed container. I have about 30 gallons in stainless steel jerry cans that i rotate every 3 months due to earthquakes and lack of fuel when they happen...
Not in my area. If it's a fixed installation it's supposed to be permitted, no tricks to get out of it. Other than just not asking and doing it anyway.Cuts out all possible harm and red tape with utility as well as any other codes.
In Texas maybe not going to work in OhioSounds like the people who say failed connectors and solar roof fires are nothing to worry about.
For me, a 6” hole In the floor and roof, metal duct, some hardware cloth. Easy fix.
Just install a gas boiler to keep it warm in there!In Texas maybe not going to work in Ohio
May be I just make it into a trailer then.Not in my area. If it's a fixed installation it's supposed to be permitted, no tricks to get out of it. Other than just not asking and doing it anyway.
Forgot to mention, it's farm use. No permits required. I just need to report the size of the building for taxes to the county Auditor.Not in my area. If it's a fixed installation it's supposed to be permitted, no tricks to get out of it. Other than just not asking and doing it anyway.
Well put.My 2p worth... As there was a gas boiler in the same room, it seems highly probably that the LFP's were not the cause of the explosion. This is for all of the reasons mentioned in this and the other thread and the fact this (as far as we know) is the only potentially reported incident compared to the, presumably, millions of LFP battery packs in use around the world.
However, if it is _possible_ that LFPs can vent hydrogen under normal operating conditions _and_ there is a quick fix to the design of our DIY battery packs to vent the hydrogen, then I guess it would make sense to remove that miniscule chance of this happening again by improved design?
The inverter / SCC overvoltage will not apply at a cell level, so just the BMS failure _could_ cause a cell overvoltage if the cells are not well balanced.Most of us have both a charging control (inverter or dedicated SCC) and a BMS on each pack. For an over-voltage to occur under this set up, both of these would need to fail together.
Thanks. From a risk perspective UL seems to think a single case is the failure mode.I've attached the full test report, while the test included multiple batteries, the report seems to indicate only one rack battery vented in the test.
IIRC the LEL of H2 is over 4% of room volume. Your exhaust is a function of the maximum off-gassing rate of the batteries. Honestly, a think a small HRV unit is all that is needed; 2CFM would be plenty for a large room, especially if you are pulling from the batteries.Small fan in a large room will not cut it. Some type of sensor to start a fan of proper size might work. Continuous venting might not be good depending on climate.
Maybe that's not too far from practical. A second cell monitoring device that doesn't participate in balancing and only controls on/off charging current? It could also be interlocked with the BMS such that if either fails, power is cut.Two BMS's! Only kidding. Seriously though... it's all about probabilities and levels of protection vs. the risk.
Unfortunately MOSFETs do fail short circuit - I had to replace one recently on a switched mode PSU (not solar related) that was shorted in all directions and blew the mains fuse.
Setup for that would be fairly easy if you use terminal blocks with 3 ports on it.Maybe that's not too far from practical. A second cell monitoring device that doesn't participate in balancing and only controls on/off charging current? It could also be interlocked with the BMS such that if either fails, power is cut.
I noticed they use the plastic cased Wistron cells for the LFP test. Curious if the more common thin walled aluminium cells used in many of the diy and rack mounted batteries behave similarly in terms of containing expansion?
Presumably 143 cubic meters is the volume needed to keep the hydrogen concentration below explosive levels, when one 5kWh battery vents. So for many who are running 20kWh+, they will be in that "danger zone" of too little air volume for a given capacity, albeit with a very small likelihood of occurrence.how many cells? they claimed a battery... too many people looking for an issue that does not exist at this point, the amount of gas that a 16s pack could put out is barely enough for the cubic meters... all of the articles did not specify how many cells just a "battery" or a "battery"'s cell output. sloppy data.
So how do we build it?Setup for that would be fairly easy if you use terminal blocks with 3 ports on it.
Can always just put them in an insulated, temp controlled heated (and possibly now, vented) case. Don't need much power to keep them warm. A 20W heater and 2" of PIR kept mine at 20C+ when was -5c outside last winter and it was only on about 50% of the time.I would have put my lfp batteries outside in a shed if it didn't get to -40*c here, and reading this makes me want to still do that!
