Xantrax freedom x1200 showing e04 code
dopeassjackson
Dutchess county ny
My xantrax x1200 is showing a high temp code but the unit had less than 500w on it and was in a 37* enclosure with none of its vents blocked. It shut down 5x in one day with this code until I switched to generator power. Then later in the day I had it on and not pulling a load from it for a few hours with no issues. Anyone else have problems with a similar xantrax freedom X unit?
I have narrowed the failure down to the inverter. With no load on the AC side it will still randomly throw this AC overload fault.
Yes the fans are running. I reset to factory default settings and disconnected the inverter from the batteries with no luck.
I have a new/used xantrax x1200 coming in a few weeks.
Solar dosnt do you any good when you cant use it...so il be running off generator power for a bit.
