I would disagree. The clearance between the roll (or accordion stack) and the case is negligible.
Why not use ratchet straps. It would look ok if the ratchet part was hidden.I thought of that some time ago. If I still had access to Poly banding equipment with the plastic corner protection, I would use it in two places. Ideal would be the type that uses heat to fuse the strap together.
Ideally a stiff flat plate would work. With just the edges, like with a strap, would leave the end cells with much less compression.Then the only way would be to apply compression to the center of the case since the aluminum is thin and the edges of the case is much thicker....right?
To bulky. Plus I'd need to find corner protectors. I could use a pocket screw jig and plywood to built a container. Clamp the pieces in place and screw it together.Why not use ratchet straps. It would look ok if the ratchet part was hidden.
The case walls appear to be the same thickness throughout.
Just like everything else, I keep looking at what others are doing. I will make up my mind at the last minute when it's time to get the parts together.
My batteries are a month away.
Perfectly acceptable in my option.So there is nothing wrong with the way I plan to compress using thick plywood and threaded rods? I am not going to use straps.
But it does pose the question if its best to clamp cells at low SOC. I would personally just clamp when fully charged, which is typically the cell state after a top balance. Then verify cell security after a discharge.
I have my BMS set to cut off at 2.875V and 3.5V per cell.Gents could I get your opinions please.
My cells arrived and I arranged in parallel and charged/top balanced up to 3.65v and down to .5amp using a 30v10a psu.
I numbered all the cells 1 through to 8. Using the 150w load tester @20a I began capacity testing all the cells down to 2.5v cut off. They all came home at around 282-4ah with the exception of cell number 7 it came in at 275ah.
The cells were charged/top balanced again then arranged in 2p4s configuration , bms (jbd) connected this time for testing. The 150w load tester reconnected @10a and the test begins.
Towards the end of the test, series #1 which contains cells #8 and #7 starts to drift away from the rest of the series around 320mV and cuts off the bms @2.5v as per attached pic.
The whole pack came home @564ah on bms shut down.
Could this be an indication of a crook cell (#7)? Would it be worth separating this cell and “exercising” it a few times to see if it gets a bit better?
I’m not to fussed about it because I can just adjust the bottom cut off up a bit and sacrifice a few ah because I’ll never use 100% of the ah anyway.
During the sales video Amy sent there was a cell "caught my eye" as being a little off from the rest of them, I wonder if this is that cell.
What are your thoughts lads?
It's not like they are written in stone. If I felt I needed to change them because of a situation I was in, then it's only a few clicks away.. That is the beauty of building my own battery and the smart Bluetooth BMS, I have complete control over it.Those are good settings and I am going to do the same.
The resistance on 7 cells was .11-.12 then 1 cell was .15What was different? The voltage, internal resistance, or both?
I would exercise it in the pack like it is. No need to separate it.
I wouldn't worry about it either. I have 8 cells coming and will never get to use the full capacity unless we have a major power outage.
