Hi, new here - thought I'd share my experience with this smart box.
I ordered and received daly 60amp smart bms +bluetooth +uart usb cable. All arrived fine.
In the box: wiring diagram, BMS, spaghetti cable, temp sensor, bluetooth, uart cable and some "on-off" switch.
Had to figure out how to initialise it, apparently, the right sequence is connect everything, then switch to On, then short P- and B-. If the temp sensor is not connected - it won't come up, which is not handy really - I don't need it as we don't have subzero temps here.
The Bluetooth connection. Well, firstly the app is hopeless - the "group" account heeds to be created by the Ali store support, the individual account wouldn't work even if you're ready to share your phone number - the app will tell you the number format is not correct. Secondly and most importantly, only once I made it work on my tablet and spare phone after a hundred of unsuccessful launches - it is simply not connecting to the BMS. Maybe it has something to do with the Android version - the manifest in the APK file states that it expects the Android at 8.1 at least. Bottom line - if you want it to work, you may need to spend more money on something more recent than just an old phone from the shelf.
The UART connection. Well, the software from the website dalyelec.cn does not work at all - connecting to the serial but no data. Took the store support few days to ship me a very outdated version on the prolific driver (and they failed in the end, I have managed to find it somewhere at the end of the day) - but it didn't change a thing. Few more days, and they send me some totally different software "Sinowealth BMS Tool" which suddenly worked. Makes me think this Daly box may be not totally Daly inside?
UART protocol. They are completely refusing to share the protocol. Perhaps they don't have it for that third party IC ? That is an important part for me as I wanted to feed the stats into my raspberry pi and store there for further processing. I will give it a go wit the document from this thread, should it not work - I tried serial sniffer and the protocol does not seem to be too complicated.
Overall the experience is quite frustrating I'd say. They initially told me that I would be able to reprogram voltages etc, then they told me "not via bluetooth, pc app only", then they told me "changes via pc app only and only 5s bms and higher, nothing whatsoever is possible for 4s". However, I seem to be able to change parameters on the PC software. They still failed to provide me with a manual, and they still can't explain what is the purpose of the switch
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. At the end of the day, it seem to do most of its job and it is 10 times cheaper than Orion so I guess all good.
