You statement makes zero sense. Your playing around in the Electrical Engineering world when you mess with power systems.
If it was not for the Electrical Engineers and other people who are skilled in working with power system doling out advice, this place would be pretty much useless.
Go tell your power company inspector you have freedom of choice and see what happens
How did you know to remove the screw? Hmmmm...
250lbs would crack a PCB. Also Injecting in silicone would do almost nothing but fill in the threads on the standoff.
Is this another SS employee account? The Hi-Pot test is a valid test and should be done again after equipment is modified. It is actually required for certification.
Are you smart enough not to touch a water pipe while taking a bath. Do you really understand what this conversation has been about?
Amazon and Signature Solar are two different types of companies. Amazon does not advertise themselves as solar experts.
I think their business is doing just fine. People are asking for information that would normally be provided by any Inverter manufacturer or distributor. Proper Wiring Diagrams are not luxury, they are essential.
The only way the forum will get better is if people with knowledge on the topics chime in and point out ways in which the industry can be made better. Your first statement implies you would prefer that the blind lead the blind. That can only lead to disaster.
