Building the sickest ® VAWT ever. Brilliant minds unite please!!
excerpt "Using a purely theoretical estimations it was noted that for the case of a lift-driven
VAWT with NACA0015 aerofoils, the rotor would be capable of self-starting if six blades
were utilized to increase solidity [19]."
It's a good thing I already made it possible to have 6 blades ;)
ok I'll try replacing the bearings then with super low friction ones and adding 3 extra blades.
I am not sure I want to keep using this rae 2822. Perhaps just go with naca 0015. this paper gary mentioned is also about naca 0015
Manually spin what you've got to get it started. See if changing angle of blade makes it work.
Wrap a rope around a wheel and pull it. Cone shaped wheel to spin faster each turn?
You could attach a drag device, with freewheel, to give it a push until lift takes over and spins it faster.
You could measure wind speed with anemometer, then drive generator as BLDC motor to spin it up to start.
What kind of bearings? Any ball/roller bearings ought to be good enough. E.g. axle bearings.
A drag device will work, but isn't what you want. Large, heavy, low producing.
The wings could be allowed to rotate orthogonal to the wind while going down wind, to serve as a drag device for high starting torque. Then lock in proper place for lift. But normally VAWT don't do that.
I would guess either you have too much friction, preventing turning. Or, blade shape/angle isn't delivering enough lift. Could be with turbulence at low height, what would have been proper angle of attack in laminar flow has no lift.
If you want a drag device, split 50 gallon drums would do that. But power output would not be "sick".
In reality, a VAWT will never be as efficient as a HAWT anyway. The upwind blades shade the downwind blades and you can't regain the lost power. HAWT blades tend to be more efficient also because the pitch is uniform for the whole rotation.
i realize that VAWT's HAWTs are more efficient. But given my local code constraints they are simply not an option for me :(
Big ones are not allowed and small ones that are allowed have to spin wayyy too fast to output anything useful. it dangerous and loud and one will need alot of them if one aspires to one day go offgrid like I do :(
Nah VAWT it is as code wise I think much is possible and with a lower rpm and less noise better for the local wild like i.e. my wife.
I just hope using lift type blades does not require the damned thing to spin faster than I deem safe. Otherwise drag type is the only sane thing left.
it's time to scale things up a bit.
I made a 2.4m high x 63cm wide straight anemometer cup drag type blade proof of concept
The current column connector is probably not strong enough to deal with this weight and as my bowden tube for the 3d printer needs replacing and I don't have the parts, it will take some time before I can post results.
If I can get it to rotate with 3 blades then I'll try 6 blades as well to see if that improves things.
if so I will add another 2.4m on top and then I just hope we'll have enough torque to spin any alternator ;)
The rpm is going to be low but that is exactly what I am hoping for. The alternator needs to compensate for that and I think we'll be covered in that department.
this is all assuming the these rather large cups will do their job to begin with. fingers crossed
whoooooot!!
It auto startes and it's spinning continuesly while we have almost no wind now at around 1m/s.
it took a force of 2.2KG to stop the rotation when measured at the end of an arm.
Damned this turbine is just waiting to collapse ;) it's crooked and another million weak spots.
I have some improvements to make and am going to like every second of it.
Do we still need to do this proney break thing or can we calculate things with this sparse info we have now? If we need prony then I have not found a good DIY source and how to translate the amount of pressure to torque.
I don't think even routing water will work ;( just too much woble.
I realize not all thread holes are with thread and tightened but that won't reduce woble. THe issue is the stock x cariage and the whole 3 wheel system on those ender 3d printers to begin with.
I will give it a try with custard first, see if I can draw a smiley face in it ;)
if I can find a laser cutter that can do 5mm of HPL (high pressure laminate) then that would solve a lot of problems if the cutter it self does not weigh too much.
... Then there is the art and science of mold flow; lines form when flow splits and rejoins. Matters aesthetically at least for finish surfaces; might affect performance in some way.
ultrasonic shaking device to agitate and encourage bubble buoyancy to float and dissipate ?
Reducing the vertical distance from the carriage to the cutter would help a lot. Even shortening the cutting tool would help. More distance is more lever arm for the force to try to rotate the assembly. Reducing cutting speed is your only other choice so the cutter has less force on it.
Thank you Gary. I am sure to try that one my new revelation turns out not to hold up. I mean who does not like some custard?.... with a smiley face routed in it ;)
Anyway what I found is 2 fold;
*) This shore 72 resin is actually pretty stiff. I just tried again bending this horrendously poured test I did earlier and this time securing the quarter disk in many more places than I did during my first tests. It does still flex ever so slightly but now it took considerably more force while the flex was much less. So it's worth a try this shore 72 resin route
*) especially since I realized the magnets will be equally attracted by coils under load from both sides. Essentially resulting in 0 bending on the disk.
Until someone shoots a hole in this reasoning I am going to focus again on getting a good solid magnet disk. We need some numbers by now ;) Blow up some car lights even with this alternator.
We're gonna need more bricks!
we'll need like 10^99999.... more bricks ;)
So I have an idea. Let's hold it up to scrutiny.
I ram 3 poles into the grass, really deep. 1 at the corner where the turbine stands. and the the other 2, 9 meters away in the other corners at 90 degrees from the turbine location.
something like my below asci art
|__
Connect those poles with 9 meter long beams, ones that do not like to bend.
Now I can make a platform that is not easy to topple over. Let some brutal wind come I would say if I was foolish enough to taunt mother nature.
But yeah, that would eliminate the need for bricks that were there all along as pseudo help.
The test rig with the bearings it self will also need a mayor overhaul. I mean 3 standard wooden 'sticks' with some screws holding the 2 OSB disks together is just not at all able to deal with lateral forces.
Well, that needs some nuance. It actually is to some extend. But not for the long run and with combat conditions in mind.
The issue with guy wires is that I can only connect to the turbine from my house. that makes for 2 guy wires rather than 4 ;(
As always, I am a sponge to suggestions.
BYW guys, all of the above still falls into the prototype phase. once we've settled on on something worthwhile I do not mind investing in more durable implementations. e.g. using actual steel or what ever rather than hap hazard 3d prints like we're doing now.
Yet the most important aspect will remain that it should be easy for anyone to duplicate and that we are not looking for the most efficient what ever.
Nah, just before the bombs are about to fall we need to be able to quickly build a few of those bad boy turbines. Or even stock pile now and make sure one does not need an actual store to get parts.
There are more clues to the success of this mission here:
I am not sure about your intend. can you please elaborate?
If this is a hollywood film chances are it ends well yes? is that what you meant?
In any case, better to be more specific. This is rather cryptic and not helpful as such.
But anyway I am rather uncertain about how I should respond at the moment.
I'll restate once again to everyone. well intended constructive criticism is always welcome, needed even. Even if the wording is a little harsh.
just let not forget we do not like blitzkriegs here
Just a little light-hearted movie line response. Carry on. Now that I'm on the thread, I will be following your progress. VAWTs are notorious underperformers compared to their horizontal counterparts. Laminar flow and air distribution seem to be the main culprits. But perhaps you've dealt with this in the previous pages.
If this is redundant, disregard:
yes redundant indeed. I have even tried to contact rossie way back based on that video. But as one might have guessed she did not feel our work here is important enough to reply. Or maybe she never got the email. spam filters are nasty these days.
Also one does not need to insert weird messages into threads in order to be able to follow them. So I kindly ask again. What was your intend?
Levity. I expect the poster was repurposing a line from the Movie "Jaws" (probably lost to you) for comedic impact. I suppose it may be seen as a "weird" reply for some. Are you easily offended?
If it does have attraction, mid-point is an astable equilibrium.
Repulsive, it should be stable.
Now I'm confused which direction with magnet passing coil of wire. It must be dragging wire after it, at least once beyond the wire?
Permanent magnets, we know how those would behave.
Finally found some time to make a schematic drawing of one of the stators a.k.a. coil disk.
the dark red slab at the bottom is a 10mm high disk of iron powder to attract the magnetic field to pass through the coils (that are not shown yet)
the pinkish/purplish fans on top of that are coil separators printed using iron powder filled filament
here we can see the 3 phases of coils.
Regarding coging. if it was a electro motor it would be a huge problem as there are as many coils per phase as there are poles.
However, this is a generator and the wind charge controller does not put a load on the coils before the voltage has reached 48 volts and the controller will short the coils if the voltage becomes greater than 56 volts.
Should I worry about coging and if so can anyone suggest a way on how to reduce that?
Also please keep in mind that there will be 2 coil disks. 1 on each side of the magnet disk.
I am guessing (a slightly educated guess that is) that a coil under load and a PM (permanent magnet) passing past it (as in a PM alternator while in operation) will experience an attractive force coercing them towards the PMs.
This of course has a similar effect on the PMs them selfs.
For an outdated representation of having 2 stators (coil disks), one on each side of the rotor (PM disk) please see my avatar image.
There is no easy answer.
I have experienced that I can take ridicule quite ok. For example if someone was to shoot holes in my Daniels Disk and point out the physics blunders made there. In such a scenario I would feel shame of course but all for the greater good. I don't mind sticking my neck out and face some backlash.
Personal attacks I have not experienced yet online so I am not certain how thick my skin would be in such a scenario.
I guess it all boils down to the wording and the intend.
One big factor here on this forum (or any other fora where one is not a moderator) is that I can't, like in real life, just turn my back and walk away.
No, we have to stay vigilante as to not allow trolls/shills to pollute the hard work that is being done here.
So if your intend was well meant then by all means join the gang, I hope you have some insights to help us out and if not that's perfectly great as well. Please enjoy this oddesy in that case.
@HighDesertOffgrid
still love you. don't be shy.
I have got some exciting update
this is what we call a magnet disk holder.
It should not really matter what material the damned thing is printed with as chances are the heat build up wont be that great (@Hedges suggested as such, granted this was while very few context was available) around this aspect of the alternator.
But then again pay close attention to the holes that are angled at 45 degrees from the plane.
you might wonder "but why my most dearest brand of newbs"
Well, so we can have m4 threads fortify the whole damned thing.
It's taking ages with trail and error to get prints to come out how they need to be. But fear not. Trail and error is what I excel at.
@justgary , @curiouscarbon I am now finetuning the first layer with a Z yes a ZET, not a ZEE hahahha) axix offset within Cura. not ideal but it does seem to work until now.
Here is another question for one?
How many watts does a 12v carlight need to blow up? Yes, you've guessed it. that is what we are gonna do!!!
@HighDesertOffgrid
I'm still watching. I have to be honest, after our initial conversation, I did try to read the entirety of this thread, but gave up around page 25. So, I'm not sure of your progress and have little to offer.
This guy seems to have success building wind generators from scratch. Perhaps you can glean something from his content.https://www.youtube.com/c/JamesBiggar/videos
