Watts Happening
I call it like I see it.
- May 3, 2022
- 811
You have all the settings you need access to on your screen the display of the inverter. The rest of the settings you don't have access to are not meant for the consumer. you could set your inverter up completely without anyone remoting in with the settings you have available on your inverter display. The password is 00000 when you are asked for this.
Here is a settings guide that is being added to the manual currently.
This is the hybrid inverter with the most access via remote of any other inverter by far. we are responsive to input but if we go too fast things will not work well.
I feel like maybe what I'm saying is being missed. There are clearly MANY more settings available via the inverter screen than there are via the web interface.
Is there a functional reason we can't have the same access both places?
Again, I don't know what settings are missing from the LCD screen of the inverter. But I'd sure like to see the web interface and LCD have continuity. Maybe there is a reason this isn't implemented, but hopefully it can be?
