Dzi, thank you! Your advice and the quick sketch are really appreciated. "Probably omissions and/or mistakes" withstanding, it is great progress forward for me. Except for the inverter can most of the original components in the video be used?
~ I am guessing that AC distribution would be important; would we plug devices into the back of the inverter or could the AC go to a breaker box? ~ Would you recommend an inverter or an inverter/charger? I don't recall that there was a way to charge batteries from shore power. Seems like it would be important if you are on the road and are running low. The inverters are cheaper.
~ Would two Battle Born LiFePO4 Deep Cycle, 100Ah 12v with built-in BMS, 3000-5000 Rechareable batteries in series work and could the system still be over-paneled in the future?
