I might need some feedback. I finally went to install 16S (48V) overkill solar BMS, but then a swarm of issues came:
Conclusion: while the BMS came with a check slip, it was apparently never checked - it must be a fake - as long as should the BMS be inserted into a regular harness and battery, the harness would go in smoke instantly. Bad cable, bad BMS, support sounds like a guy is reading from a Chinese manual while can't speak Chinese, so he's using Google translate. Almost like Will's communication with some far east companies, except you get all this at the premium US $$$.
Given how complex the assembly of BMS is - it is for ham radio on the road, so far it needs to be vibration resistant, so it would take a week to rebuild it all...
--Petr
- One balance lead was missing BC12 on drawing. I found the same connector with wire at home and inserted it into the connector (which had a slot covered in white silicone, so far wire was never there).
- Tripple checked everything - voltages were correct
- Inserted balance connector into BMS - one wire went up in smoke
- Contacted support, not much useful information, except to open the BMS and look at the resistors
- Even before I opened BMS I saw what the problem was: the BMS is apparently 20S one, and some pins were shortened by solder bridges, including a bridge spanning from BC12 to BC13, shorting the cell (on the board it is BC17,18, and 19)
- Contacted support. Look at resistors (resistors are looking brand new, and measure brand new, no problem here)
- Removed bridge between BC17 and 18, yet the BMS would not work.
--Petr
