One part of my design isn't going to adhere to this currently. Off the Main, the bottom 100a feeds a panel that feeds an existing feed with #8 (L1,L2,N,G#10) N&G I didn't draw, in the ground already that I'll be switching on (grid feed) when needed. I'm adding a #4 neutral to this path from the inverters along with the hots in new conduit. So there will be two neutrals connected all the time in separate conduits...I cannot run the #4 in the same as the existing #8. Should I run a breaker on the neutrals to keep them separate and force them to use the appropriate feed in associated conduit so they can do that electromagnetic cancel thing you mentioned? I think the panels I'm buying have this plug on neutral feature...if I get breakers that handle the two hots and neutral...maybe that will fix it?
