Just to update this thread.
I ordered new breakers and fuse holders from
ZJ Beny, they have several different websites, I found the downloads didn't work on the solar website, but you can find them on the
main website. Ordering which was via Alibaba was a little different, but all worked very well. I paid on the 31 October, and received the items today. I was kept constantly updated via WhatsApp, so all was very easy, there was only one slight bit of confusion, and that was I couldn't work out how to pay - for some reason she hadn't raised an invoice, once that was done it appeared on Alibaba and I could easily pay.
The breakers are no polarity or bi-directional, so perfect for solar battery storage systems, and SolarEdge suggest to use their products in one of their documents, so hopefully that's a good sign.
I ended up going with 160A breaker for each battery shelf, and 250A for the whole rack - I figured that due to the time it takes a breaker to trip it would be fine for momentary peaks - the maximum continuous current fromt the inverter would be about 160A. 63A breakers for the charge controllers, and 32A for the solar combiners, and individual fuse holders for each string of panels.
I ordered the Lynx Shunt VE in the end, just to make things tidier really.
Main cable run I've order 120mm cable for busbar to shunt, runs from battery to busbar are 70mm, and there will be two runs (2 x positive, 2 x negative) from the Lynx Power in to the inverter, both in 70mm. MPPT to Lynx Power in will be 35mm cable. Cables are 0361TQ which is double insulated.
I have on order 250A T Class for each battery, and 400A for the whole rack.
Cable size conversion:
4/0 is 107 mm2 - Available cable size 120mm2
1/0 is 53.5mm2 - Available cable size 70mm2
006 is 13.3 mm2 - Available cable size 16mm2
010 is 5.26mm2 - Available cable size 6mm2
PS Next items to buy are the cable lugs, I've
found these which look substantial.
