I've got the manual!Perhaps if you asked her to send the manual we could take a look at it.
Also the inverter is set at 11.8-14.6v as of now.
Hi Steve,That is a High Frequency Inverter I believe, especially at that price, it absolutely cannot be a Low Frequency model. Possibly Transformerless ?
That is NOTHING like the Low Frequency Unit I used.
Thanks. The low voltage is good and you should be able to set your BMS to cut off at 2.5 volts without any problems. I guess you could use the BMS to cut off at whatever high voltage you want since you don't have any choice but to have them set those voltages. But 14.6 may be a little too high, and may not protect your cells if the BMS fails. I see the inverter is programmable for different batteries. Can they also set the voltages for those parameters? Like something between 13.8 and 14.6 volts?Also the inverter is set at 11.8-14.6v as of now.
Glad it helped you!This thread has been very helpful to me. Thank you.
I do need a 2000 watt inverter /charger though (the size these skip). Any suggestions?
You can use any setting if they left any settings open for you to use. Of course you do not want to use the De-sulphation cycle. If you used the lead acid setting you would be limiting the charge to 3.4 volts per cell. There is not much capacity to be gained above 3.4 volts and 3.0 volts at the bottom. You would be leaving around 20% on the table but extending the life of the cells. I don't see anything mentioned relating to float voltages in the manual....just find that interesting.Good to know mine could still be a LF haha
And huh I didn't think to do that and forgot to check this thread again. Might be too late. But also, is that the only difference in charging different battery types? Cuz I see lithium specific components and lead-acid specific stuff like MPPTs and is the compatibility solely the voltages? Interesting.
Also, if the vast majority of my power comes from solar panels going through my mppt, are the inverter's voltages as relevant? As it will mostly be converting power from DC to AC? Or am I getting that wrong and electricity just be flowing everywhere all the time all willy nilly
I also linked to a 2000 watt inverter for less than $500 in my post above.This thread has been very helpful to me. Thank you.
Please let us know how it woks, with $100 off is pretty price and I have been looking at LF inverter for awhile now, I hope you can also take the pictures of the inside, thanks. BTW, what did you do toget lower price? I contact YIYEN directly on ALIBABA but the total price is higher than what I can buy on EBAY.Glad it helped you!
This is the one I got:
https://www.ebay.com/itm/2KW-DC12-or-24V-AC120-240V-split-phase-pure-sine-wave-inverter-battery-charger/233677828193?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
I have no idea if it's good or bad, mine's set to come in march/april. But it's a 2kw for a solid price. I'm new to this so other's might have better advice than me
I just asked. I inquired to jackyzhang910 asking about a 2Kw inverter, she sent me that link, which totals to $460 with shipping, and I said I had to think about it because I was trying to keep my total price under $400. And she offered to shave the price down by I think $85, so not quite $100, but still a solid chunk.Please let us know how it woks, with $100 off is pretty price and I have been looking at LF inverter for awhile now, I hope you can also take the pictures of the inside, thanks. BTW, what did you do toget lower price? I contact YIYEN directly on ALIBABA but the total price is higher than what I can buy on EBAY.
got that link she sent?I just asked. I inquired to jackyzhang910 asking about a 2Kw inverter, she sent me that link, which totals to $460 with shipping, and I said I had to think about it because I was trying to keep my total price under $400. And she offered to shave the price down by I think $85, so not quite $100, but still a solid chunk.
Though to be honest I am second guessing this decision.. Some of the unknowns that people are bringing up and the lack of clarity with the manual are making me wonder. I really like the look of the one Gazoo posted above as I see it is definitely a LF, clearly has 6kw surge, and also voltage is customizable.
I do too but remember it is not a cream of the crop inverter either. I don't know what the voltage settings limits are. The settings on the Samlex EVO inverters is mind boggling...but they are very expensive. The AMPINVT is better known than the inverter you ordered and is sold on Amazon.I really like the look of the one Gazoo posted above as I see it is definitely a LF, clearly has 6kw surge, and also voltage is customizable.
That's the difference between Tier-1 Product versus Tier-3.I do too but remember it is not a cream of the crop inverter either. I don't know what the voltage settings limits are. The settings on the Samlex EVO inverters is mind boggling...but they are very expensive. The AMPINVT is better known than the inverter you ordered and is sold on Amazon.
If you can ask jackyzhang910 the questions I posted above and you get a favorable response, especially if it is a LF inverter and you can use the other charge profile settings, then you might be happy with it.
Asking those questions! We'll see..I do too but remember it is not a cream of the crop inverter either. I don't know what the voltage settings limits are. The settings on the Samlex EVO inverters is mind boggling...but they are very expensive. The AMPINVT is better known than the inverter you ordered and is sold on Amazon.
Good to know I can 2-day that to me if this one craps out on me!Here is the 2kw AMPINVT listing on Amazon :
Also, I was wondering, does anybody use two inverters, one big and one little?
I'll explain..
The only AC load I require running 24/7 is my mini fridge which is I believe only 50-60W, and other than that my basic electric needs will be DC (lights, electronics charging, fans, etc..)
So it seems sort of silly to have an inverter that draws power on standby when I am barely using any of its power.
Is it logical to get a small 150W inverter (something like this, but would maybe try and find a 150w) and run the fridge off of that 24/7, and then only turn on and use the full size 2Kw inverter when necessary?
By start is that referring to getting the mini fridge cold the very first time?Question would be whether the small inverter could start the motor in your fridge. Assume 5x the amperage/wattage rating on the label.
What percentage of the time is refrigerator on?
You could get an inverter with sleep mode, where it wakes up periodically to see if there is a load.
You could switch it off at night, make it coast on the cold it's built up, so less battery needed (for a system charged by PV)
Starting surge meaning every time the motor is turned on.By start is that referring to getting the mini fridge cold the very first time?
Or does it peak every time the mini fridge turns on throughout the day?
